raptor clutch cover HELP!!!
Old Mar 6, 2004 | 07:17 PM
Mr45auto's Avatar
Default raptor clutch cover HELP!!!
To make a long story short, I screwed up! I had some stripped threads on the clutch cover where the external oil line attatches by the oil filter. I bought a heli coil to repair it and in the process of drilling it I went too damned far and drilled the little hole at the end to 13/32 or 10mm. It looked about half that size originally....DANG!!! Anyhow will this hurt anything? Is this cover doomed? Please lemme know if I've got to hunt up a new one ASAP!! Thanks[img]i/expressions/face-icon-small-blush.gif[/img]
Old Mar 6, 2004 | 09:13 PM
sixsixT's Avatar
I don't see why it would matter, as long as you didn't drill thu the other side of the pocket that is at the bottom of the hole.
Old Mar 6, 2004 | 10:52 PM
Outlawlawndragster's Avatar
At worst have it welded back up and then drill and tap . Make sure you use a bottom tap to finish it and always use cutting oil for aluminum when tapping
And always remember " **** Happens "
Old Mar 7, 2004 | 01:44 PM
Mr45auto's Avatar
Well, I didnt use cutting oil or anything not in the kit. It was just a drill bit a tap and of course the heli coil and install tool. Dang things are expensive too. I talked to the service manager at a local dealer and he didnt think it was too much to be concerned about as the banjo bolt wont flow any more regardless of how big I drilled the flippin hole. Does anyone have a clutch cover laying around that can refresh the memory on just how big that hole is originally? I think it was small but I'm not really sure.
Old Mar 7, 2004 | 02:13 PM
sixsixT's Avatar
I think it's about 3/16" I could measure it if you like.
Old Mar 7, 2004 | 02:25 PM
Mr45auto's Avatar
I was just double checking to see if it really was significantly smaller or if I just nutted up over nothing. I wonder if it'll lower pressure on something important? Do you know if this is an oil feed or return line? I get flow to the head as I've opened the little screw on the head and oil very freely flowed out.
Old Mar 7, 2004 | 02:48 PM
sixsixT's Avatar
It's a feed line, the oil returns back down along the timing chain. The ID of the tube is smaller than the hole you drilled out so I agree with what the service guy said.
Old Mar 8, 2004 | 07:56 AM
Ward660R's Avatar
Gotta add my 2 bits.
Not only is that Heli coil expensive its hard as hell to find!!! I went all over before I found one. Then I never used it. I had the hole welded up and then tapped out for $15. I plan on tapping it out to a 1/4NPT and using a braided stainless line. I am waiting until I have to pull the head off next time though.
The hole: I can stick a 9/64 drill bit in and its just about perfect. The next size up (which I have now forgoten in the 2 minutes it took to walk to the shop) would not fit in. So I wuld say its a 9/64 hole. I also agree about the size of the line and hole in the bolt only letting it flow so much.
STLyamwar
Jul 25, 2020 04:44 AM
ghost civic
Jan 15, 2020 07:43 AM
Cummins Driver
Sep 11, 2019 01:22 PM
ghost civic
Jul 15, 2015 10:48 PM
brad wheeler
Jul 13, 2015 11:19 PM
