Rear Skid Plate Bolts
Old 03-09-2004 | 12:59 PM
Tyme's Avatar
Default Rear Skid Plate Bolts
In order to remove the rear skid plate from my 02 Raptor, I had to grind off the heads of the rear bolts. Since then I have hit them with every penetrating fluid known to man, and tried to unscrew them with vice grips. Since I am posting this, you may have realized they are still on the quad. Any Ideas on how to get them out????
Old 03-09-2004 | 03:05 PM
sAyIt_fmf's Avatar
You could try a bit of heat and an ez-out kit.
Or you can use a carbide drill bit and go up in sizes a bit at a time until it pops free....You will most likely want to run a thread chaser through the hole when your done.
Old 03-09-2004 | 03:10 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
what he said
and if there is enough meat left,,,,grind (dremel tool) a slot in the shaft,,,,,heat it really good with a torch,,,and unscrew it with a large standard screwdriver.
heat is the key (to melt any glue on the bolt)
Old 03-09-2004 | 03:19 PM
Tyme's Avatar
My concern is the housing is aluminum, and the bolts are steel. The steel will win the heat battle everytime. I have been told it will be a delicate balancing act between the two.
Polaris5
08-29-2015 09:11 PM
MikeyBoyesq
08-10-2015 11:11 AM
house1
08-09-2015 10:49 PM
Bell21
07-28-2015 06:52 AM
95wolv
07-21-2015 12:25 PM
Quick Reply: Rear Skid Plate Bolts
