Questions on rims?
Questions on rims?
i know the bolt pattern will work, but i have had ohter rims that are the same bolt pattern and almost the same exact rim and i got them on and everything and when i went to ride the tires wobbled super bad and they were on tight, i think it was the offset, but i dont know if the grizzly rims would be the same
Questions on rims?
What models?
Here's what I found:
First the front wheels have the same offsets (4+2) on all years of the Kodiak and Grizzly, so there should be no problem there.
As for the rear wheels:
All 400 Kodiaks use a 3+5 offset.
The 450 Kodiak uses a 5+3 offset.
The Grizzly (660) uses a 5+3 offset.
So if you are going to put the Grizzly wheels on a 400 Kodiak they are going to sit inward a lot.
Hope this helps.
EDIT: Sorry, I should have looked at you sig. You have a 400. So, yeah, they well make the rear narrower about 2 inches on both sides. I'm not sure if that will make the tires hit the exhaust or not, but it might look kind of funny. [img]i/expressions/face-icon-small-smile.gif[/img]
Hope this helps.
greg86hd
09-16-2015 12:32 AM
