raptor shocks on a banshee
Old Mar 10, 2004 | 11:02 PM
98yamyz's Avatar
Default raptor shocks on a banshee
does anyone know if raptor shocks will fit on a banshee or does anyone know the length of raptor shocks
Old Mar 10, 2004 | 11:03 PM
RoostItUp's Avatar
it will prolly do the opposite of putting banshee shocks on a rappy, it will most likly raise it. They will bolt on though if thats what you were wondering.
Old Mar 10, 2004 | 11:12 PM
98yamyz's Avatar
any idea on how much it will raise it?
Old Mar 10, 2004 | 11:16 PM
RoostItUp's Avatar
it lowered my rappy about 1-2 inches, so itll prolly raise it the same.
Old Mar 10, 2004 | 11:22 PM
98yamyz's Avatar
thanks ill let ya know what happens
Old Mar 11, 2004 | 12:42 AM
RoostKing's Avatar
Unless you already have the raptor shocks, go for the YFZ450 shocks instead. They fit with just a tad of modification and are worlds better.
RoostKing...
Old Mar 11, 2004 | 06:12 PM
98yamyz's Avatar
got yfz shocks actually what kind of modifications will i have?
Old Mar 11, 2004 | 06:48 PM
Buttermilk385's Avatar
I've put YFZ shocks on my Banshee.
I had to do some grinding on the top shock mount to remove enough material to clear the shock. Didn't take much.
The bottom shock mount on the lower a-arm will need to have some material removed to clear the shock on the inner side (nearest the frame).
For stock a-arms, I also had to take a piece of bar stock and a good sized hammer, and make an indention on the top of the lower a-arm to allow the shock to have enough clearance to drop into the a-arm so the bolt holes would line up. If you have aftermarket a-arms, they should bolt up without modding, as they did to my aftermarket a-arms.
Regards,
buttermilk385
bmxatv10
Oct 14, 2022 06:23 PM
cboler9
Sep 24, 2015 08:35 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 12, 2015 09:39 AM
