raptor rev limiter
Old Mar 11, 2004 | 04:15 PM
racerxc450's Avatar
Default raptor rev limiter
i have a raptor nd i need a new rev limiter ....does anyone know who make a good one?? i know big gun does but is there anyone else??.
thanks.
Old Mar 11, 2004 | 07:09 PM
maddog56's Avatar
did you fry the old one? if not, what kind of mods do you have done to your bike?
Old Mar 11, 2004 | 07:24 PM
racerxc450's Avatar
nu uh... i didnt fry the old one i have a 11:1 wiseco piston,hot cam stage 2, jet kit airfilter,fmf titanium 4 with powerbomb header,edelbrock crb,prodesign intake manifold i need a new aftermarket one i hit the limter all the tim...
thanks for your help
Old Mar 11, 2004 | 07:36 PM
1BADRAPTOR's Avatar
change your gearing cuz you shouldent be hitting it with those mods,the rev is set somewhere in the 9,000 range....I dont even hit it and im putting out 60 sum horses
Old Mar 11, 2004 | 07:38 PM
1BADRAPTOR's Avatar
and if your on a YFZ450 you still shouldent be hitting it.. jmo
Old Mar 11, 2004 | 07:42 PM
Dfitz's Avatar
You need to shift sooner. With your mods you are just getting to the rev limiter sooner. But changing the gearing can make a big difference. Depends on what you are doing.
Raptorboy4life's Avatar
Does the rev limiter affect anything to make it faster or somthing or is it specifically for reverse?
Old Mar 12, 2004 | 01:28 AM
racerxc450's Avatar
alright yall thanks for the help
Old Mar 12, 2004 | 05:10 PM
maddog56's Avatar
It raises the rev limit from 9k to get more hp from modified machines. That said, you shouldnt really be hitting the rev limiter and still making power unless you have got an extreme cam in there with a moderate compression piston and very high end pipe. Most raptors start dropping off peak by 7500-8000 with aftermarket cams.
Old Mar 12, 2004 | 07:01 PM
UBETRUN's Avatar
My Craycraft signature 686 (minus the SS valves) would hammer the rev limiter. It had a Stage 2 cam. I never dyno'd it so I don't know exactly where it made peak HP but it was still stretching my arms when the rev limiter kicked in. I had 18" rear tires and 12/40 sprockets, geared for max acceleration over short distances.
I rode a stock bore drag Raptor with a Stage 2 cam and 13/40 gears with 20" rear tires. Because it took longer to rev, I could feel the power drop slightly before the rev limiter kicked in.
It's a delicate tuning balance between max acceleration vs. the number of times you have to shift.
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
