back fire on de-ceclleration
Old Mar 12, 2004 | 10:22 PM
spacollie's Avatar
Default back fire on de-ceclleration
What would be the cause of backfire on decelleration?
Old Mar 12, 2004 | 11:08 PM
dragracer789's Avatar
It might be to lean.
Old Mar 13, 2004 | 12:26 AM
caliraptor's Avatar
Mine backfires once in a while, what it has done lately is turn off completely while idling. I think I just need to adjust the valves and jet up some more [img]i/expressions/face-icon-small-cool.gif[/img]
Old Mar 13, 2004 | 02:51 AM
hondabuster's Avatar
Backfire on decell, is caused by a lean idle circuit, or intake leak, or exhaust leak. Most likely , the mixture screw needs to be turned out(rich), 1/4 to 1/2 turn. If that doesnt fix it, look for leaks.
Old Mar 13, 2004 | 03:51 AM
caliraptor's Avatar
Should I get some bigger pilots? I will try to find a leak at the intake boots or the header tomorrow. Im 2.5 turns out on both mixture screws, so I will go with 3 turns out. Thanks for the help guys!
Old Mar 13, 2004 | 05:23 AM
Ward660R's Avatar
Go to bigger pilots after 4 turns out on the mixture screws.
Reactant
Mar 30, 2022 02:08 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
Countrygirl1976
Jul 13, 2015 10:08 AM
Coryco
Jul 6, 2015 07:30 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
