banshee questions
Old Mar 13, 2004 | 05:27 PM
HughJazz's Avatar
Default banshee questions
I am looking at buying an 88 banshee and was wondering when they changed the frt suspension. Is they anything else that changed or that I should look for?
Old Mar 13, 2004 | 06:05 PM
HiFlyinRaptorRyder's Avatar
It will have j-arms unless the guy that owns it has had the conversion done. Before you buy it, you should check the compression and of course ride it.
Old Mar 13, 2004 | 06:06 PM
Forgot to mention when you check compression, if the cylinders are over 10 psi away from each other (ex. one cylinder is #100 and the other is #120) it needs a rebuild.
Old Mar 13, 2004 | 06:56 PM
HughJazz's Avatar
Is there a big difference in preformanced between the J-arm and the A arms.
thanks for the info
2004LEBANSHEE's Avatar
Also take off the air filter and check the intake for dirt.
HINT: There shouldnt be any
Old Mar 13, 2004 | 06:58 PM
Preformance wise not really. A arms are stronger. Better for MX. J arms are lighter better for drag. Also more after market for a arms
shimanok2
Jan 29, 2016 07:37 PM
bigred20653
Oct 2, 2015 10:05 AM
mark23
Oct 1, 2015 09:57 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
bigred20653
Sep 19, 2015 02:11 PM
