are banshee, blaster, and warrior axles the same???
hi, i need a new axle for my warrior. is it true that they are interchangeable, the only difference i may think there is would be width? anybody know?
I think also the raptor too because I know when I ordered my durablue axle it had the installation steps if you were putting it on a banshee which there was like one extra part and it had steps for either a warrior or blaster I can't remember which.
I know that a stock Raptor axle will not work. My friend bought a used Warrior axle for a Raptor hoping that it would fit but, it was to big to fit in the housing. I'm not sure about the Blaster and Banshee.
Go to Yamaha of Troy and then go to parts finder, then Yamaha, then ATV, and check and see if the axels all have the same part number. If they do then they will work.
Hope this helps.
Never mind about checking, I already did. They are all different numbers.
Hope this helps.
I know for sure that banshee and blaster axles are interchangable. I have a banshee one on my blaster. I think that the Banshee is the widest, then the raptor, and then the blaster. i don't think that warrior axles fit into the mix though. I am looking at my rockymountainatv catalog, and I see that the Banshee, Raptor, and Blaster axles are the same number, except for the last letter; and that the Warrior's is different. So, I guess that you will have to go with a new axle, and you can't use the Banshee, Raptor or Blaster.
