File valve down for stage 2 hotcam?
Old Mar 15, 2004 | 03:57 AM
AustinONeal's Avatar
Default File valve down for stage 2 hotcam?
My local dealer said they had to file a valve down for my stage 2 hotcam is that right?
Old Mar 15, 2004 | 05:41 AM
Ward660R's Avatar
They probably meant grind down the valve guide. If they had too yours would be the first I have heard of that had to be done for a stage 2. If they are trying to charge you more for doing it, I would double check it just in case.
Old Mar 15, 2004 | 01:44 PM
all he told me is that it would drive the valve into somthing and break it and it would get in the motor
Old Mar 15, 2004 | 01:57 PM
garyc660R's Avatar
I have never heard of anyone having too do this too use the Stage 2 Hotcam...anyone else have any info?
Old Mar 15, 2004 | 03:35 PM
oh great thats good now they are cutting into my motor
Old Mar 15, 2004 | 04:43 PM
garyc660R's Avatar
Originally posted by: BartlettRacing
they dont need to cut any valves !!!! all they need to do is run a file on the top of one valve guied ....only need to remove a few thousands off the guied ...... it's very simple to do........ ten min max !!! 99% the clearance is ok on .....
99% of the time the clearance is ok? Is there a potential binding issue with the spring and the guide??
Old Mar 15, 2004 | 08:39 PM
so do you think that they are filing the valve giude or are they cuttin the valve i might have misunderstood him is what you said he going to do?
Old Mar 15, 2004 | 10:01 PM
RaptorForever's Avatar
Which valve guide is it that needs to be filed? I am about to put my bike back together w/ a stage II
Old Mar 15, 2004 | 10:33 PM
Ugintel's Avatar
new timing chain every 100 hours?!?! anyone elese think this needs to be done? I have prolly 25 hours on my new piston and cam, thats NOT that mich time really, that like replacing the chain 2-3 times every year.......
Old Mar 16, 2004 | 02:56 AM
Ward660R's Avatar
Raptorforever, it is the middle intake guide. You should check the clearance before you start grinding away.
I think the cam chain thing is a good idea. I don't know if 100 hours is overkill or not.....better safe than sorry. As cheap as the chain is and as easy as it is to replace I think why not.
