FCR install?
Old Mar 15, 2004 | 03:25 PM
FarmStud's Avatar
Default FCR install?
What do you do with the vacuum hoses, I assume you just cap them off? Any other tips or tricks? They should be coming by the end of the week, just wanted to hear some info before I get started. Thanks
Old Mar 15, 2004 | 03:29 PM
Yamaha660R's Avatar
I'm getting a set as well, so I'll have to watch this topic as well.
Old Mar 15, 2004 | 04:32 PM
sixsixT's Avatar
I don't think you want to block off any of the hoses.
Old Mar 15, 2004 | 04:58 PM
BigScary's Avatar
yes they are just vacum hoses from the stock carbs........you can cut them off if you don't intend to run stock carbs again........or you can plug the end up and zip ty them up..........
Note
do NOT do this to the crank case breather........
Old Mar 15, 2004 | 05:13 PM
RaptorOwner's Avatar
When I took my FCR's off my motor I noticed that there is a vacuum tube between both carbs at the top that was just open. I dont know if it were to hurt anything but the carb was clean when I took it off.
Old Mar 15, 2004 | 09:21 PM
FarmStud's Avatar
If you didn't block the vacuum tubes, wouldn't you be sucking unfiltered air into the engine, or am I wrong?
ReconBayou
Oct 31, 2022 05:37 PM
2many2ride
Sep 27, 2015 04:35 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
toonces
Sep 5, 2015 01:14 PM
