Warrior starter clutch (help)
Has any of you changed one out before?
I've never been dug into a 4 stroke before with electric start before. My stater isn't turing the motor, but it is turning, but my pull starter will turn it over. When i got the quad, i'd pull the cord, and it would turn the motor over, AND turn the starter as well. But i got the starter button to work, and it freed the starter, so now i can pull the cord, and it won't turn the starter.
But like i said, the starter isn't turning my motor. Can ya help me?
I just bought a warrior and the starter clutch (one way bearing) went out about an hour after i bought it. I would suggest taking it to someone as the flywheel is a very tight fit and takes a special puller. Also the bearing has to be put back in a certain way. It cost me 244$ to get mine replaced and that was with only 32$ in labor
