sputtering engine
Old Jul 13, 2000 | 01:52 PM
MUDMAN03's Avatar
i was riding yesterday and dove about 1/4 - 1/2 at full throttle and i was going past my neighbor's house and he had a bunch of his friends swimmin and as i was goin past my t-wolf started sputtering and it could barely run. what is going on it has happened before but i leaned off my air/fuel mixture and it helped for a while. could i need to adjust my valve clearance? it also did more backfiring than it did actual running. what is going on!?
Old Jul 17, 2000 | 04:20 PM
mudrabbit's Avatar
Check out the other posts on sputtering and missing engines, most say a good carb cleaning does the trick. I am very careful with my atv's, always stored in a shed and I had trash get into the carb of a Big Bear, ran perfect after carb cleaning. It would crank and idle perfect but sputter and back fire when opened over half throttle. Even though my BB had a plastic gas tank condensation and enough rust collected to cause problems. Do you ever drain the carb by the drain screw on the side near the bottom, usually has a hose connected. Good idea to drain occasionaly to help prevent water and crud from collecting.
Old Jul 17, 2000 | 05:43 PM
QuadSpeed's Avatar
SOUNDS LIKE A DIRTY CARB OR A FAULED PLUG.
Old Jul 17, 2000 | 07:24 PM
DunePilot858's Avatar
Make sure your gas cap vent hose isn't twisted kinked or otherwise.
Old Jul 17, 2000 | 11:30 PM
REDYAM's Avatar
backfire through the pipe means your lean backfire through the carb means your rich becouse you were a little past 1/4 throttle means youre pilot jet is clogged. unclog it and you will be fine
COFatboy
May 2, 2020 12:06 AM
ghost civic
Jul 30, 2015 04:09 PM
ghost civic
Jul 27, 2015 03:15 AM
bpegram84
Jul 22, 2015 08:15 AM
bpegram84
Jul 22, 2015 08:12 AM
