WHEELies
Old Mar 16, 2004 | 09:59 PM
soonLTZ400's Avatar
Default WHEELies
i have a warroir as you can see and i just started doin wheelies, i rev it in 1st then pop the clutch to get it up...ne suggestions on how to do them or how to keep them up nd sht
as u can see im an amature any advice would be awsome
Old Mar 16, 2004 | 10:08 PM
BornToRide101's Avatar
Default WHEELies
yo i have a warrior two and am also trying 2 prefect my wheelies! i find it helps if you drive slow in gear then bounc back on the seat as you giv it some gas.
good luck!
Old Mar 16, 2004 | 10:11 PM
BigBoyToyz's Avatar
Default WHEELies
Learning to use your brake is key.
Old Mar 16, 2004 | 10:12 PM
Thormotox448's Avatar
Default WHEELies
when i first started to do wheelies and find a good blance point i would put one of my feet in the rear grab bar
Old Mar 16, 2004 | 10:15 PM
Rider1169's Avatar
Default WHEELies
blance point and back brake are key, as he said. just go 1st or 2nd and low rpms, or powerband, gun it for a sec and pull up, get it in ur balance poin(it takes time and practice to find) and keep it there. if u go to far back, tap ur brake to recock u and either bring it down or keep it going. i reccomend u pratice in a grassy field. its fine when ur learning to kit ur grab bar, thats y they are there, but when u learn to us the brake, u wont need it. good luck. every quad has its own balance point.
Old Mar 16, 2004 | 10:17 PM
soonLTZ400's Avatar
Default WHEELies
good stuff good stuff
Old Mar 16, 2004 | 10:19 PM
hondaracer305's Avatar
Default WHEELies
Thats how i did it, i put my feet on the grabbar and once you get used to it coming back and hitting, then you know that when you are sitting down, it wont come back and it makes you more comfortable while riding one. And being able to brake is definately the most important part of a wheelie, it can save your azz sometimes. Also, a good way to keep it up when you are at the top of a rev, is make it come back past the balance point and ride the brakes so it slows it down, then you can start it over again with lower rpm's to ride it longer, this is key while riding extended wheelies.
Old Mar 16, 2004 | 10:31 PM
warrior68man's Avatar
Default WHEELies
While I still havent mastered it, I think the best way(for me anyway) if to do just keep trying them sitting down...i have yet to hit my grab bar...but i think if I go up a little higher i will have the balance point....but its hard...lol...i onno...no real reason why i am posting this but you know.
Old Mar 17, 2004 | 08:10 PM
soonLTZ400's Avatar
Default WHEELies
thanx 4 the help guys i will try this stuff next time i go
i hate talkin bout it cuz all i wanna do is go ride now nd i cant
Old Mar 17, 2004 | 08:29 PM
veryfastshee's Avatar
Default WHEELies
as you wheelie try slipping the clutch to control it, it is less abrupt than using brakes
