kodiak sputtering???????
Mine did the same thing I rode it home and fueled up with some fresh gas problem went away probably put another 150 miles on it and not a single sputer since . Try fresh gas. mine started sputering after a long ride at full throttle too.
From what you described it could be suck'n air check both clamps on your carb and make sure there tight. It also could have got a little trash in the carb, drain it and see if that helps, before ya do anything else drain your carb again, might save ya little time and some gas. Good luck and let us know.
TAZ
TAZ
I ride with a oo' Kodiak and his sputters all the time, but mainly when he's down in a mud hole. I'm a mechanic and I have seen the same thing on old trucks with carbs. The jetting is just a little to rich and runs fine when it's not under a load, but when stressed the carb. loads up and starts to flood. It also does the same in reverse the dealer said it was a rev limiter, but another friend has a Grizzly and he can haul butt in reverse, so I'm not sure if it's a rev limiter.
Well today i pulled drained the card and tried it and still sputtering, so I pulled it off clean the carb, there was a little grime in the diafram (not an great speller) so i cleaned it out and now it runs great, thanks everyone.
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
