Changing sprockets on Raptor, a few questions.
Old Mar 22, 2004 | 04:36 PM
jscarbrough's Avatar
Default Changing sprockets on Raptor, a few questions.
Will it shorten the gears dramatically?
Also 1 tooth in the front = 4 in the rear correct?
Old Mar 22, 2004 | 04:43 PM
Foxracin's Avatar
I mostly ride trails and I put a 12T sprocket and you can tell the difference the front end comes up a whole lot easier to get over trees or other things but it does feel like u need another gear on the top end but if i could change it I would probably keep it like I have it now. I would highly recomend it for trail riders.
Old Mar 22, 2004 | 04:55 PM
Raptorx44's Avatar
what about going up 2 in the rear, how much would that effect it?
Old Mar 22, 2004 | 04:57 PM
Perhaps a better idea would be to go to 38 in the rear? That would still give me a increase in accel and not take too much off of the top end.
Would that just be a waste of money and time?
Old Mar 22, 2004 | 04:59 PM
  #15
Raptorx44's Avatar
anyone running a 13\38 setup?
Old Mar 22, 2004 | 05:11 PM
  #16
caliraptor's Avatar
Running a 13/38 would be like going to a 14T, almost. If you want to get a bit more accel, but no lose too much top speed, go with a 13/41-2.
Old Mar 22, 2004 | 05:19 PM
  #17
LoneWolfMcQuade's Avatar
[img]i/expressions/face-icon-small-cool.gif[/img] I have an 01 model raptor. I mostly ride trails and gravel roads here in mountainous East Tennessee. I knew right away the raptor was geared to high for my needs. I went down 1 tooth on the front sprocket and up 4 teeth on the rear sprocket. Went ahead and bought a longer chain while I was at it. The change-out was easy. The only thing extra I had to do was shim out my swing arm guard (with washers and longer bolts) to clear the larger sprocket in the back. The results were awesome. Increased acceleration significantly. Wheelies easily without having to sit on the back of the seat. Comes up in 2nd easily. Don't know about top end, I've never found a place to open her up. The raptor will easily tractor in gear (idle with hands off the throttle) on level ground. You will definitely not be sorry if you make these changes.
LoneWolf
Bratman2
Aug 6, 2022 01:42 AM
Anomers
Aug 16, 2015 11:06 AM
oldschool64
Aug 12, 2015 07:13 AM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
