Carb troubles
Old Jul 14, 2000 | 11:30 PM
99_warrior_350's Avatar
I was out riding my warrior today and it didn't want to idle. So i adjusted the idle and now the carb will make a back firing noise and shake real bad when it idles and then it will stall out. what else should i try?
99 warrior
Old Jul 14, 2000 | 11:41 PM
Tree Farmer's Avatar
When you "adjusted the idle," did you adjust the idle mixture screw or the throttle idle position (stop) screw? Backfiring generally indicates too fuel-lean a mixture.
Tree Farmer
Old Jul 14, 2000 | 11:48 PM
I adjusted the idle screw.
Old Jul 15, 2000 | 12:32 AM
THEXOTIC1's Avatar
Your bike is fairly new. But sounds like the pilot jet may have a blockage. Take the carb off and remove the bowl. then remove the little brass jets. I use an ocy/act torch tip cleaning tool the get in the small jets holes. You can use a strand of thin bailing wire. then use carb cleaner and clean it out real good. the gas will turn into a varnish if it sits in the carb for a while. Also check the simple things first like the air filter.
GregM
Mar 6, 2018 06:53 AM
Aitch
Jul 21, 2015 09:40 PM
Dirtbikemike1
Jul 21, 2015 04:13 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
