dies when i turn left
Old Mar 25, 2004 | 08:40 AM
Yamaha4eva's Avatar
Default dies when i turn left
if ur engine is dying when u turn left its not your carb...it just doesnt make sense if you can turn right
Old Mar 25, 2004 | 09:04 AM
BigBearFX's Avatar
i am almost sure its something with you electrical wiring
Shav0's Avatar
my blaster used to do a similar thing. The cable was adjusted too tight so when I turned to the left it reved real high because it pulled the cable on its own. Try adjusting the cable where it meets the thumb throtle and see if that helps. You will have to adjust the idle with it.
Old Mar 25, 2004 | 09:23 AM
sAyIt_fmf's Avatar
My guess would be the throttle cable...does it do the same thing sitting still?
Turning right would have the tendency to pull on the throttle cable...turning left would push...I bet the slide is closing when you turn left...can you verify this with the air filter off, looking at the slides?
just a thought
Old Mar 25, 2004 | 03:58 PM
  #15
alf's Avatar
alf
it turned out to be the cable i put it all the way in and adjusted the idel on the carb and it runs great now thanks for the help
Old Mar 25, 2004 | 04:02 PM
  #16
AlphaRaptor660R's Avatar
Glad you fixed it!
Old Mar 25, 2004 | 05:08 PM
  #17
Raptorboy4life's Avatar
Originally posted by: AlphaRaptor660R
Glad you fixed it!
me too... lol
bzdok1234
30
Feb 23, 2016 01:55 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
