dies when i turn left
Old Mar 24, 2004 | 08:43 PM
alf's Avatar
alf
Default dies when i turn left
I put the trinity 2 into 1 carb kit on my banshee and now when i turn hard to the left it boggs down and dies any ideas
Old Mar 24, 2004 | 08:48 PM
AlphaRaptor660R's Avatar
When you turn left?? Could you be pulling a cable or something with your handle bars when you turn.??? I would start there...
Old Mar 24, 2004 | 08:57 PM
dragracer789's Avatar
Yes most likely an eletricle wire getting pulled. Its happend to me a few times.
Old Mar 24, 2004 | 09:03 PM
lafngas's Avatar
check you adjustment on the choke....might be pulling the cable when you turn causing the choke to close.....happened on my Raptor once ......chased that for awhile! Good luck!
Old Mar 24, 2004 | 09:57 PM
Jarod's Avatar
i had a simailr prob on my bb, the key switch wire had broken and if i went straight or turned left it was fine, but if i turned sharp right it would stall. check your wires cables on your handlebars
Old Mar 24, 2004 | 10:01 PM
alf's Avatar
alf
i checked the wires i can pull on all of them and nothing happens but when i turn it is stalls out i think it is something with my carb. should i take off my cable and just let it hang the turn it or what o and after i turn it a ways it runs on one cylinder
Old Mar 24, 2004 | 10:38 PM
shadowmaker's Avatar
AHhhh just dont turn left. LOL Sorry couldnt resist.
Has to be something in the cables or wiring.
Brad
Old Mar 25, 2004 | 01:45 AM
LTZ's Avatar
LTZ
Turning left while riding or just turning the bars while sitting still?
Old Mar 25, 2004 | 02:11 AM
JLsparky7's Avatar
Brad
lol
Old Mar 25, 2004 | 02:15 AM
RoughRider01's Avatar
Does it speed up when you turn it to the right? Sounds like the throttle cable is too tight , likes its getting pulled to the right and slack to the left. I would try loosening up the throttle cable and speed up the idle.
