Raptor
Old Apr 5, 2004 | 02:28 PM
oldmanIndy's Avatar
Default Raptor
Who makes the best carb intake manifold for my 01 raptor? The old one will not stay on the carb's. I need the email or the phone number.
Tks,
mike
Old Apr 5, 2004 | 02:35 PM
RoostItUp's Avatar
Default Raptor
Are you sure you don't mean the carb boots?
Old Apr 5, 2004 | 02:42 PM
oldmanIndy's Avatar
Default Raptor
Yes you are right, the intake boots or carb boots, its what's go's onto the carb's.
Old Apr 5, 2004 | 03:13 PM
Yamaha660R's Avatar
Default Raptor
UPP makes a good set of carb boots.
www.albaaction.com sells them. But I'm sure you can look around at some high performance parts websites and find them as well.
Old Apr 5, 2004 | 03:51 PM
kuz28's Avatar
Default Raptor
Got em...never came off after installation.
your actually dealing with 2 problems...your mixture may be off...and the bad design of the boots. a quick fix to get you back on the trail today....would be to take the clamp(s) off from around the Boot. there is a spacer that rests between the clamp ends and fits over the screw. Take the spacer off and file it down. you only want to take off a Human hair or two worth of metal. if you take off to much. the clamp will tightened down to much and possibly cut into the carb boot.
good luck
Old Apr 5, 2004 | 04:19 PM
radfastdude7777777's Avatar
Default Raptor
i had the same problems and then i found manifolds that are plastic and click in instead of sliding like the stock ones which slide out and i have not had problems since and dont buy the stock ones they are crap
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
