03 Raptor Problem
Old Apr 12, 2004 | 08:52 AM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
Default 03 Raptor Problem
Originally posted by: trdtacoma
Check for comp. kinda sounds like you overheated the ol gale.
thats what it sounds like,,,,,,if the carbs didnt blow off
what did the plug look like upon removal????
sounds like fuel shortage (lean),,,,which can do damage
check your compression
Old Apr 12, 2004 | 12:13 PM
quadracer18's Avatar
Ya but before you check your compression deal with the carb first...take the jets out and hit them with some gunkout then take your air filter off and spray a little either (starting fluid) while your cranking it over..Sometimes it just takes a little extra to fire it up...Just don't spray to much starting fluid in it or you could burn something up...But try that first..I had a similar problem with my scrammy and that got her fired back up..
Old Apr 12, 2004 | 02:14 PM
YamahaRiderOnly's Avatar
the plug was pretty bad so i put a new one in
Old Apr 12, 2004 | 02:46 PM
caliraptor's Avatar
Im guessing it has something to do with your CDI, I bet a wire is loose and your not getting spark. I had that happen to me a while back and the ORANGE wire was loose. Pull your plug and check for spark.
Old Apr 13, 2004 | 10:30 PM
  #15
I took it to my Dealer and they are going to fix it for me whatever is wrong, but I was talking to this guy that knows alot about quads and he says when you ride them alot in 5th gear pinned for long periods of times it messes them up. I do it alot and do it for a quater mile pretty much maybe even a mile at some times. Me and my buddy always race top speed and go for ever to see who pulls away. But what do you guys think about that
Old Apr 13, 2004 | 11:30 PM
  #16
WheelieKing's Avatar
i think your dealer is gonna charge you alotta money to fix it.
Old Apr 13, 2004 | 11:39 PM
  #17
Why do you think its gonna cost me alot of money, what do you think could be wrong with it?
Old Apr 13, 2004 | 11:44 PM
  #18
Hozed's Avatar
you could have smoked your piston & rings... thats why they were telling you to check your comp.
i dont see a stock quad doing that so soon though.
Old Apr 13, 2004 | 11:47 PM
  #19
I am not sure what is wrong, Its got compression and it does roll over, it just wont start. it smells alot when i push the start button. it might be getting to much gas or something I'm not sure at all
Old Apr 13, 2004 | 11:58 PM
  #20
kwiknik's Avatar
Try unpluging the CDI then pluging it back up. I had a similar problem when I changed my CDI.
