blaster riders please read
Old Apr 12, 2004 | 03:14 PM
iwannabfast's Avatar
Default blaster riders please read
i am wanting to sell my 95 scrammy and get a blaster i know thats probably a bad idea lol but i want a little sport quad anyway what do i need to check besides compression on a used blaster and are there any main problems in the 99-02 models
thanks
Old Apr 12, 2004 | 03:31 PM
Shav0's Avatar
no,
see if you can get a 03, better brakes and stuff.
Old Apr 12, 2004 | 03:36 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
thanks
like shavo said 03 is revised with a new headlight and disc brakes
what size rider are you??? Height/Weight?
Old Apr 12, 2004 | 04:02 PM
phishnlabbat's Avatar
Check the oil injection system. If the oil injection is blocked off, make sure it was done properly. Some people just remove the tank and cut the lines from the carb to the pump inside the case. Often people forget to plug the fitting on the carb and dirt gets in through the opening and causes damage to the top end. Also check all the bushings and bearings. The a-arm bushings are known to wear out rather frequently, but are inexpensive to replace ($30 on ebay). As mentioned before if you buy a blaster made prior to 03, make sure all the brakes work good. Other than that they are great little quads that can be made pretty quick with a couple mods.
Old Apr 12, 2004 | 10:35 PM
ok i had some more questions oh yeah i am 5 foot 5 and 170 pounds, what is the compression i should look for in a used blaster like 125 or 130?
Customer Service #1
May 15, 2020 08:46 AM
kbazzy
Sep 26, 2015 11:26 AM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
black_thunder
Sep 20, 2015 10:21 PM
awer1968
Sep 8, 2015 11:02 AM
