Banshee Maintenance...
Old Apr 12, 2004 | 11:45 PM
y2kgt's Avatar
Default Banshee Maintenance...
I just bought my 2004 shee and I am new to the 2 stroke world, I need all the information i can get in order to keep my shee running good and lasting long, any help is appreciated...
Old Apr 12, 2004 | 11:59 PM
FMF's Avatar
FMF
I put a new Top end and bearings in my Banshee every year and I Change the oil ones a Mouth 7 keep evey thing Greased up good.
Old Apr 13, 2004 | 12:19 AM
FBOMBERS's Avatar
Keep the air filter clean or better yet swap to a pro design filter set up.I only use Maxima 927 Castor Oil in any 2-stroke.I've seen Banshee's go 4 years without any top end rebuilds on this oil.Keep the trans. oil changed regularly.Banshee's like a lightweight gear oil.I've had best luck with regular and override tranny's using the Suzuki 10w 40 motor oil or the Honda Trans oil.
Old Apr 17, 2004 | 01:56 PM
Chazzman's Avatar
Whats the cheapest, And good oil for a tranny, i gota replace my clutches and i need to know some good oil?...
Old Apr 17, 2004 | 06:15 PM
FBOMBERS's Avatar
I must admit I've had the best luck with plain ol' Suzuki 10w40 motor oil from your dealer,it's like 2.50 a quart.Do not use any other kinda motor oil,they have anti-friction agents that'll cause your clutches to slip.
Old Apr 17, 2004 | 08:10 PM
Rider1169's Avatar
do regualr maintence, make sure ur plugs are the proper color, if not rejet it so its running perfect. rebuild ur topends when u loose power, shouldnt have to worry bout that unless u really race tho, only like once ever 2 years, its good to do it once every year or so. change ur plugs often also
Kaleb_00
Jun 1, 2016 09:15 AM
greek271
Aug 8, 2015 08:16 PM
JohnnySplat
Aug 6, 2015 12:07 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
