2002 Banshee wont go into gear!
Old Apr 13, 2004 | 03:17 PM
Chazzman's Avatar
Default 2002 Banshee wont go into gear!
I got 2002 banshee, and u push down on the shifter it clicks, But u can roll the quad back and forth. And when its running it wont move, Its like the bike is staying in neutral.
Any ideas let me know.. Charlie Thanks
Old Apr 13, 2004 | 03:32 PM
Shav0's Avatar
. . .Do you have a chain? ? ?
haha
lol
Old Apr 13, 2004 | 04:05 PM
FBOMBERS's Avatar
Check and make sure the nut hasn't came of the sprocket.It's happened to me before.The sprocket will still set on the shaft it just isn't on the splines.Other than that you may have a burnt clutch.
Old Apr 13, 2004 | 04:24 PM
Chazzman's Avatar
Yes have a chain, i will check the sproket tonight... Ne other ideas?.. before i go look at it?...
Old Apr 13, 2004 | 04:29 PM
Chazzman's Avatar
Is there any way it is inside the tranny?... I wonder it was going good then jsut stopped and reved high like it hit netrual, Seems like it is it jsut wont go into gear at all..
Old Apr 13, 2004 | 05:52 PM
FBOMBERS's Avatar
Check and see if it will click through all 6 gears.If it will and the sprocket nut is still on I'd check the clutch.If it is the clutch go with a Yamaha factory replacement street bike clutch with big Barnett springs and put in a pancake bearing to help against the clutch welding up.The clutch sells for about 65-70 bucks and the springs are 12-13 bucks.The pancake bearing will set ya back about 50 bucks but it's good insurance and you'll never have to worry about your clutch welding up.We run this clutch in all our 100hp drag bikes and I've seen em' last 1-2 years under these conditions.They are super strong and easy to set up.BTW do ya change your tranny fluid regularly?
Old Apr 17, 2004 | 01:54 PM
Chazzman's Avatar
Do i really need the bearing?... I can have the $$$ for the clutch and springs, i got 90$ Can i just buy the clutch and bearing no springs?.. if that will work.. Or jsut the clutch and the springs, But i dont want the clutch to be any harder to pull i lik eit soft..
Let me know thanks
Old Apr 17, 2004 | 06:11 PM
FBOMBERS's Avatar
I've seen Banshee's run fine without the bearing,even when highly modified.I only recommend it to my customers because I've seen alot of em' weld everything together.Yes you can run stock springs,for normal riding they're fine.But I do highly recommend the street bike clutches.Let me know if ya need the part # for the fibers,you can order steels for a banshee,they'll work fine.
Old Apr 17, 2004 | 08:08 PM
Rider1169's Avatar
well, will any gear work? is ur sproket totally stripped?
Old Apr 17, 2004 | 09:02 PM
bagz's Avatar
make sure you press down for first maybe you do 6up
