Turbo for a blaster ???
Old Apr 15, 2004 | 12:30 AM
wanaply21's Avatar
Default Turbo for a blaster ???
yo ttrain just leave, everytime u post u make urself look like an idiot, if ud like to save urself of more humiliation thats what i suggest
Old Apr 15, 2004 | 12:32 AM
stevendsm95gst's Avatar
That wasnt very nice of you to say that to me. You find that article for me in dirtwheels buddy.
Then go ahead and do a search here on these forums for blaster and turbo and you will find my post about that paticular turbo. I would be suprised if dirtwheels even knew where to get a Te04h
Old Apr 15, 2004 | 12:45 AM
AngryHampster's Avatar
turboing a blaster = waste of time and money.
Even with a really really small turbo it wouldnt spool till about 7000RPM's...and that would just be retarded.
oh, and tTrain, it does't matter what you read, its whether or not you understood what you read, in this case, i doubt you did.
Old Apr 15, 2004 | 12:49 AM
wanaply21's Avatar
i thougt u could set a turbo to spool at a lower rpm
Old Apr 15, 2004 | 01:09 AM
  #15
Outlawlawndragster's Avatar
Depends on the turbine and pitch . Some of the variable vein turbos spool up quick . But dont waste your money on a blaster SUPERMOD if you want to spend money and go fast buy a Polaris RMK 800 crate motor there about 2700 add clutches and you have a 140HP ATV .
Or if you just want something exotic build a pulse jet and set it into the frame of the Blaster . You would be the hit of the Neiborhood with a pulse jet .
They scream out at 155 Decibels at full on
Old Apr 15, 2004 | 03:11 AM
  #16
BeerSmurf's Avatar
Turbo on a single cylinder loop scavenge two stroke is somewhat problematic to start with.
A Blaster is probably an especially poor choice for a turbo installation.
You can easily make more power and heat than the engine can take with conventional mods, pipe, porting, carb etc.
Adding manifold pressure to the mix is probably not going to cause anything but grief.
I think you might be able to do some good with some kind of turbo long rod Banshee motor converted to thru scavenge with a poppet valve top end.
At that point you are really talking exotic, hybrid type stuff.
If you want to write the check, I'd love to see it built.
Old Apr 15, 2004 | 10:51 AM
  #17
Shav0's Avatar
Ttrain you should post more often. I always look forward to getting up in the morning and seeing what you have to say, it cracks me up every time. Keep em comin'
lol
Old Apr 15, 2004 | 12:36 PM
  #18
THEXOTIC1's Avatar
WHY!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!
Waste of money You should think about brakes first. Those blasters dont stop for nothing unless you have a new one with the hydrolic brakes
Old Apr 15, 2004 | 02:23 PM
  #19
Knutz99's Avatar
just get a shee
Old Apr 29, 2004 | 06:01 AM
  #20
GIMPED's Avatar
HEY TTRAIN........JUST ASK YOUR DADDY WHEN HE WAKES UP. HE HAS ALL THE ANSWERS IM SURE
