Perfect seal for a hole in blaster oil tank!
I found the perfect thing to seal a hole that you may get in your blaster oil tank....1st tank your tank off...and clean it really good around the hole with gasoline..cut out a piece out of a yamalube quart of oil..and use that plastic to go over the hole take a propane torch and heat it over the hole and press it down to get it to stick....becareful thou...and make sure everything is clean so you dont stop up your oil line......
Nice, RED GREEN style until you brought it home and actually fixed it the right way by replacing it right? LOL, maybe dress it up with some duct tape while your at it? Nice ingenuity though! I only do stuff like that to get me home and hold me off till the right replacement comes along... Waiting to get a Pingry Oil tank due to a crack from the factory weld on my Raptor oil tank supply as we speak... Got an abortion half aluminum weld and crazy glue/silicon mess on it, not proud of it whatsoever, but it gets me riding till my Pingry gets here!
