raptor weight issue
#21
raptor weight issue
I know that the sub-frame weighs 6 more lbs going from 01 to 02. A while ago there was a guy on here that had a list of ways that he said cut the raptors weight by like 50 lbs. some of the easiest ways to lose weight is by removing the lights, get some carbon fiber wheels, and like they said a new axle. To be honest its really going to be hard to get the weight down cause a lot of the weight is in the motor ( I read a mag where they said that the motor weights 103lbs). So maybe try a search to find it, hope this helps.
#23
raptor weight issue
Originally posted by: Eceriderjbomb
Who cares durablue is junk anyways.. This is how i see it... If you want to have the same weight as the yfz... The rider and the machine loose it half and half... 25 from each would get you alot.. Get the v light bumper, a new swing arm and antidurablue axle....1 bad raptor is right the axles are like a feather. remeber aluminum is a good thing...
-Cruz-
#24
raptor weight issue
Originally posted by: Raptorboy4life
good job buddy they do suck all of them suck!!!!!!!!!!!! i mean the axle is alright not that many probs but there warrenty sucks!!!!!!!!!! do not buy durablue do not buy durablue do not buy durablue do not buy durablue do not buy durablue do not buy durablue
-Cruz-
-Cruz-
#25
raptor weight issue
I wouldent want to own one after hearing the horror storys that are on the forums. Think about it brother you know there is better axles.. There are people hear that said that when there axle bent they tryed to return it and some dumb reason durajunk made up to not give it to them. Its good that you have had good luck with them but if i had the choice i wouldent get one and im telling people wqhat i have heard..
#26
