will this work?
Old Apr 25, 2004 | 10:22 PM
hondaguy2's Avatar
Default will this work?
if i put the tires on our big bear and put them backwards will They work better in the mud? i also have sqeaking coming from the front end it sounds like a cv joint. it only happens when i put a strain on the tranny like sppeeding up fast can you help me?
Old Apr 25, 2004 | 10:25 PM
Raptorboy4life's Avatar
well for the tires.... what are you smoking over there?? as for the squeeking it might be a shock????
Old Apr 25, 2004 | 10:31 PM
hondaguy2's Avatar
why wouldn't it work? and it is definatley not a shock because it sqeauks faster when it gets going faster........even when you're on a smooth road
Old Apr 25, 2004 | 10:34 PM
oh i dont know about the noise do you notice a preformance difference? as for the tires what do you mean? they will be the sos (same ol' ****)
Old Apr 25, 2004 | 10:39 PM
hondaguy2's Avatar
no it doesn't affect it at all just sqeauks and it drives me crazy. about the tires i mean if i take the front right take it put it on the left side and the the tread will be backwards.
Old Apr 25, 2004 | 10:49 PM
Hellbilly132002's Avatar
ur tires will wear down hella quick like that. the tread is only meant to go one way and the treads are made to go with the forward motion...as for mud...it shud make mudding better, but on the road it will suck and u will reck and have an annurisym.
Old Apr 25, 2004 | 10:53 PM
hondaguy2's Avatar
i probably will turn them around then. but the sqeaking is definatley coming from the cv joint and i just greased them too.[img]i/expressions/face-icon-small-confused.gif[/img]
Old Apr 25, 2004 | 11:06 PM
hondaguy2's Avatar
could this be a bad cv joint?
Old Apr 25, 2004 | 11:11 PM
yaaaaaa's Avatar
Not all tires are directional tires. So you might not wear them down as fast. if they are worn down though the lugs will be deeper.
Old Apr 25, 2004 | 11:13 PM
hondaguy2's Avatar
they are just stock tires
hugemoth
Jul 20, 2020 03:28 AM
rcappie4
Jul 18, 2015 07:51 AM
timster911
Jul 13, 2015 01:57 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
