Someone tried ?: Dyna FS Programmable Banshee Ignition CDI
I currently own two and am about to buy a third. THey work great if you are into tuning for max performance and you know how to tune. If you don't know what you are doing, you can screw it up quickly. 7 degrees is a bit much for a stock motor.
I've got the programmable Dyna FS on my Banshee, too. I really like it.
It's a bolt on installation. Takes maybe five minutes at the most.
I like the ability to program in different curves and simply select the one you want with the flip of a switch.
However, the timing plates are simpler and cheaper. You don't get the hotter spark of the Dyna though.
Regards,
buttermilk385
Regards,
buttermilk385
The four factory settings are just different curves. Different ones are just more aggressive in different rpm ranges.
I use four curves I programmed myself. I can switch between them for different track conditions. I can pick a curve that has less advance at low-mid so that my bike doesn't spin as bad coming out of turns. For a large track where my motor needs overrev, I can pick a curve where my timing starts retarding as soon as peak power is made so it can rev out farther. Many different ways to adjust it.
Sw00p
09-24-2015 02:50 PM
