blaster wont start!
Old May 4, 2004 | 05:50 PM
muddbogger's Avatar
Default blaster wont start!
i have a 5 day old blaster and i havent started it in 2 days and i tried to start it and it wont start! it makes the sound to start but wont fire up, i use the choke on and off and still nothing,idk wat to do , i washed it but i pout tape over the air hole thing under sthe seat so nothing got in there, does ne1 no wat to do?
Old May 4, 2004 | 05:51 PM
sandblaster360's Avatar
change the plugs.
Old May 4, 2004 | 06:30 PM
Rider1169's Avatar
if its not that old i bet its not the plugs, it would have given him trouble last time it ran. they can sometiems be hard to start, make sure there is nothing in the snorkel under the seat, and that the tape is off
Old May 4, 2004 | 07:56 PM
raptorblasterracer's Avatar
change plugs, MAKE SURE U USE MIX LOL, turn off fuel when done ridding, try pull startin it so it can clear all the shyt u pumped into it lol
hopfully u didnt flood it
change plugs or pull the old one n clean it off
Old May 4, 2004 | 08:03 PM
Devin246's Avatar
Dont forget these things...
Make sure key is in and on
Hold the clutch
Put the choke on
Make sure ur slide switch is on run
Old May 4, 2004 | 08:14 PM
maddog56's Avatar
Gas mixture? Gas on?
Probably flooded it or the mix is too rich and you fouled a plug.
Old May 9, 2004 | 01:14 AM
TR1994Blaster's Avatar
if you were riding it rough you cud have wor out the rings u have to breake it in good first
Shooterj2003
Jun 21, 2015 09:02 PM
1000gade
May 27, 2015 12:37 PM
B4NSH333
May 26, 2015 06:55 AM
littleatvr
May 18, 2000 07:45 PM
dunc_n
Aug 26, 1999 09:32 PM
