YFZ oil change help
Old May 14, 2004 | 01:57 AM
Carmelo15's Avatar
Default YFZ oil change help
i want to change my engine oil but the bolts that hold the engine guard are on so tightly. how do i get these off?
Old May 14, 2004 | 02:02 AM
solostyle's Avatar
Mine weren't on that tight. Are you talking about underneath the bike? Just make sure u find the right allen wrench and a tight fitting phillips head screwdriver!
Old May 14, 2004 | 02:04 AM
Carmelo15's Avatar
yeawh the bolts underneat the engine. i couldnt pry them loose with a standard allen wrench. what is a phillips head screwdriver?
Old May 14, 2004 | 06:56 AM
Hozed's Avatar
[img]i/expressions/face-icon-small-shocked.gif[/img]
the opposite of a flat head....
Old May 14, 2004 | 12:43 PM
solostyle's Avatar
Make sure your allen wrench fits perfect before u start prying away. You can grab a nut wrench and put the allen wrench through the round end of the nut wrench and use it for leverage.
Old May 14, 2004 | 12:50 PM
stevendsm95gst's Avatar
stand your bike up. It may be easier for you.
Old May 14, 2004 | 01:30 PM
LokiDS650's Avatar
for your tool box get the allen head sockets 3/8 drive that fit your rachet you will use them a lot. They come in a set of 7 or 8 metric or standard just don't over tighten the blots its well worth the expence then to fiddle with a standard allen wrench.
Old May 14, 2004 | 03:05 PM
schwendi's Avatar
Those arent allen bolts they are Torx. Get the right tools and try again ...
Old May 14, 2004 | 03:21 PM
yfzblaster1's Avatar
Make sure you going the right way. If your drunk make sure you remember to refill the oil after you drain and change the filter. I hear running them without oil is bad?? Who woulda thought. [img]i/expressions/face-icon-small-confused.gif[/img]
ultangler
Nov 30, 2024 01:35 AM
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Gwolf228
Feb 18, 2017 01:36 AM
Jackg17
Sep 26, 2015 09:30 PM
