yamaha bad brakes
Old May 18, 2004 | 02:36 PM
hondaguy2's Avatar
Default yamaha bad brakes
i have a big bear and the brakes never work on it. i put new pads in the back and adjusted them. well the first mud puddle i went through they didn't work. so i adjust them again and i just keeps happening[img]i/expressions/face-icon-small-mad.gif[/img]. thefront brakes are the same way. i was thinking about putting disk brakes in. the newer big bear have disk brakes would they work? or should i use some from the wolverine.[img]i/expressions/face-icon-small-confused.gif[/img]
Old May 18, 2004 | 02:52 PM
Shav0's Avatar
Most likley the newer style disc's would work, as long as they didn't change too muhc in the front end. There is probably a kit you can buy to do the change over.
Old May 18, 2004 | 03:30 PM
AlaskaBoy's Avatar
hondaguy,
The new Big Bears still have drum brakes in the rear. Sounds like you are getting contamination in the drums, does your drums use O-rings? AlaskaBoy.
Old May 18, 2004 | 03:50 PM
hondaguy2's Avatar
yes it has seals but this is a 13 year old machine so they are bad probaly. i dont want to replace the seals though. i just want better brakes. by the way the back is a disk brake and that never works so i don't know what to do
Old May 19, 2004 | 12:23 PM
AlaskaBoy's Avatar
hondaguy,
I was not aware that yours had came with rear disc brakes. I wonder why thy went to a drum later.
I had the same problem with my King Quad and after replacing the seals with a new set they would last longer, at least the fronts. I never use the back ones so I do not bother putting new shoes on it. I found the local rubber hose dealer had them in stock and I took him my old one and he matched it up and charged me 3 bucks for 5 of them. My seals had gotten cracked and also had some flat spots allowing water and sand to get in there and the shoes would wear realy fast.
But as you stated you do not want to replace them because it is 13 years old and just want better brakes, well good luck in your venture.
AlaskaBoy.
Old May 19, 2004 | 01:33 PM
hondaguy2's Avatar
thanks for your help alaskaboy i'll keep searching. By the way you have a really nice kodiak. wish i had one [img]i/expressions/face-icon-small-smile.gif[/img]
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Oct 16, 2019 12:11 PM
greg74
Sep 10, 2019 03:03 PM
Stirling
Aug 9, 2015 01:49 PM
SixSpeed5
8
Aug 2, 2015 05:38 PM
