The BEST Piston and Cam
My advice is to make up your mind about what you want out of your motor, then make your purchases.
First if you plan on Spraying when drag racing then spend your money on a better set-up for your quad(swing-arm,gearing,tires,shocks,etc..) then you can shoot a 50 shot and be competitive with any $$$$$$ big bore motor.
Or if you are getting tired of the Juice,and just want a quick Rappy to play around on and win a drag or two every now and then, then sell the NOS and save your money and gett you the WHOLE KIT that you want. But remeber you wil still need all the set-up parts I mentioned above.
Rule of thumb. Stock compression motor(or lower) shooting 25 shot will gain you almost 25hp!! Hi compression motor shooting a 25 shot will gain you about 15HP(maybe). so in the end you will not have gained much speed at all.
Bigger.
Bigger.
exmotocrosser
Sep 13, 2019 06:12 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
