2 Banshee questions
Old May 21, 2004 | 12:25 PM
DeutschlandUberAlles's Avatar
Default 2 Banshee questions
Hello Folks 2 quick questions if anyone can help.
I have an 03 banshee, I adjusted the chain because it seemed too loose about 3 weeks ago, now when i hit a jump the back end makes a cluncking sound, this wasn't happening before, is it possible that the chain is still too loose or could this be because perhaps i didn't adjust the tighteners evenly?
Another thing, I've just bought some durablue 1.5" wheel spacers for the front end, if anyone reading this has them or any comments i'd love to hear, they come with longers studs then the stockers, but they are kind of loose in the hubs and i can't find the same stud as the stocker in longer form, i've been to UAP and the stock banshee hub stud is the exact same as the one off a Geo metro.. problem is they dont make a longer one.. anyone out there have any solutions, or else im selling these bad boys and taking a bigtime loss.
Thanks
Brad
Old May 21, 2004 | 12:32 PM
nickxc's Avatar
Im not sure about the dura blue extenders but as far as the chain It might still be too loose or it could be too tight Im not really sure it should be loose enough that you have about 2 inches of up and down movement when you have pressure on the seat about equal to your body weight. also you must make sure the chain tensioners are equally adjusted. go to bansheehq.com and ask Im sure you will get an answer from someone who has had the same problem they are all banshee riders.
Old May 21, 2004 | 05:23 PM
Thanks I'll give bansheehq a try if no one on here has the same problems, how do you like those Sst pipes by the way?
shimanok2
Jan 29, 2016 07:37 PM
bigred20653
Oct 2, 2015 10:05 AM
mark23
Oct 1, 2015 09:57 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
bigred20653
Sep 19, 2015 02:11 PM
