Raptor chain tighting
Old May 23, 2004 | 10:48 PM
FaSsO's Avatar
Default Raptor chain tighting
bolts on the swing are and nothin happened do i need to loosen my axle bolts or what if i turn them bolt out will go loos or tighten plz help i need to ride
Old May 24, 2004 | 10:58 AM
raptormattman's Avatar
First you have to loosen the carrier bolts 17mm that go from your sprocket side to the brake side. Then loosen the lock nut 12mm. While looking at it from behind (left) is tightening the chain (right ) is loosening.
Old May 24, 2004 | 01:43 PM
Dfitz's Avatar
Good luck you will have to play with it to see what works best for you to get it right. You can't just go with the marks the swing arm and carrier they are not correct. I love my raptor but this is one of worst designs that anyone has. JMO
Old May 25, 2004 | 01:40 AM
Catalac's Avatar
What do you mean the index marks are not accurate?
Crap, I just tightened up my chain for the first time and used them as the reference. How do I do it right if I screwed the axle allignment up?
Old May 25, 2004 | 10:09 AM
Dfitz's Avatar
On mine when I set the adjuster screws on the same marks on both sides my axle is not strait. So I measure my axle to the frame for my adjusting.
Old May 25, 2004 | 10:53 AM
CaptBags's Avatar
Mine sucks, I only have adjustment marks on the left side. I'm taking a shot in the dark on the right. Plus is is absolutely ridiculous to get to the adjuster on the right side w/ the brake lines there. Horrid design!
Old May 25, 2004 | 03:32 PM
pinheadedjoker's Avatar
how much play is the chain supposed to have when it is properly tightened
Old May 25, 2004 | 04:14 PM
CaptBags's Avatar
I think the Manual says 1.25 to 1.75 in up and, down movement.
is that when you are sitting on it or is that when there is no load/stress?
Old May 25, 2004 | 04:17 PM
warwgn's Avatar
thats off the bike by the manual, but it is best to put your weight on it when adjusting.
