Yamaha warrior rocker arm/ valve please look
hey i just put in the ALBA cam kit for my 2000 yamaha warrior it came with valve springs and i was wondering if i had to agjust the part of the rocker arm that comes down ontop of the valve. rite now there is about 1/4 inch of space between the end of the rocker arm and the top of the valve?
thanx guys
thanx guys
You need to adjust the valves. I don't have my book here right now but it is probably .010 on the intake valve and .012 on the exhaust. Be sure to adjust them at zero lift too.
I had to crank the valve adjusters way down on mine too. A lil side note though, a torque stuffer with a .450 cam wont work good. The .450 kills the bottom end, and the torque stuffer kills the top end so your left with weakness all over.
For red bull, dont forget to degree that cam where the sheet says. It will run good at stock setting but youll be missing out on some extra torque and hp.
