need help changing jetting on 01 warrior!
Old May 31, 2004 | 12:41 AM
domba420's Avatar
Default need help changing jetting on 01 warrior!
i need to rejet the carb in my warrior, ive heard its possible to be done without buying a jet kit, can anyone tell me how?
Old May 31, 2004 | 10:42 AM
yamahawarriormods's Avatar
if you have exuast and a slite air bob mod use a 148 main jet that you can buy from a local dealer then turn your air/fuel screw to about 2 1/2 turns out
Old Jun 1, 2004 | 08:41 PM
NLWarrior01's Avatar
I've just finished a bit of that myself ...
FMF recommendations for the Powercore IV is for a 150-152 main, forget the air/fuel screw settings but 1.5 sticks in my mind. I have a uni filter in addition to the FMF exhaust.
I installed a 150 main tonight, but I never checked the needle clip position or tampered with the air fuel mix. As of right now this is how it's working ..
idling - punch the throttle wot, machine dies
putting along - punch the throttle wot, machine takes off like scalded cat
zinging along - punch the throttle wot and hold it, machine sputters almost like on a rev limiter
I need a few clean plugs to check the jetting properly, but I don't think it's running rich at the moment as the plug is quite dry and not black at all ...any suggestions?
STLyamwar
Jul 25, 2020 04:44 AM
Espo720
Technical and How-To Articles
Aug 19, 2015 02:44 PM
house1
Aug 9, 2015 10:49 PM
manuelrivera
Aug 8, 2015 04:34 PM
Reactant
Jul 16, 2015 10:29 PM
