Warrior...No Spark?
Originally posted by: warrior68man
could it be my stator?
Could be your coil .. 1990-2002 primary resistance 0.36 - 0.48 secondary resistance 5.44 - 7.36 K (ohms)
but heres the specs to check your stator as well
1990- charging coil (white to white) 0.70 - 0.86
1990- pickup coil (yellow to blue) 171 - 209
1990- source coil (white/green to red) 270 - 330 (ohms)
Hope this helps ya.
Hope this helps ya.
No problem... I just replaced a stator last november, would fire right up and run for about 10 mins then just quit, the source coil would fail when it got hot. If you end up needing a new stator I got mine from rickystator , half the price of a yamaha oem part and a warranty to boot.
#16
My step brother's warrior does this too. We haven't taken time to figure out why. (Probably battery connection) But when he stands up and jumps on the seat while holding the starter button it turns over and fires right off.
#17
[img]i/expressions/face-icon-small-disgusted.gif[/img][img]i/expressions/face-icon-small-confused.gif[/img] LET ME KNOW IF YOU GET IT FIXED MY 97 WARRIOR IS DOING THE SAME THING.I PUT ON A NEW COIL,CDI BOX AND GOT A USED STATER OFF OF EBAY AND STILL NO FIRE. THANKS HOPE YOU GET IT RUNNING. I LET YOU KNOW IF GET MINE GOING .
#18
My wife says I need a new spark too... anyone know if a new stator, Starter, or coil will help my problem? I always though it was a loose connection.. but you never know.... I never tired jumping up and down on the seat while trying to get my motor running though..sounds kind of kinky.....
#20
I'm hoping someone else recalls the loose wire deal from a while back.... The thread indicated it was pretty common and had the same characteristics...
