Need technical help with my Raptor!
Old Jun 8, 2004 | 12:21 AM
  #31
lovbyts's Avatar
Default Need technical help with my Raptor!
Just run regular unleaded unless you have high compression pistons otherwise it doesn’t make much difference unless you are racing and need the extra .01 sec
When you adjusted your floats did they still move freely? I have read that some people after setting them to 13mm (pre assembly) that the tab was bent so much the float did not move. You have to have some movement to the floats or that's a bad thing..
I would also pull the plug out and check to make sure its the correct one.
Old Jun 8, 2004 | 12:29 AM
  #32
Rook's Avatar
When I moved the tabs, the floats still moved freely. I'll double check on the plug.
Old Jun 8, 2004 | 11:45 PM
  #33
Rook's Avatar
OK, Now I REALLY need HELP!!!!!! I took the tops of the carbs off just to make sure the needles were pushed in all of the way. So then I took them out to make sure nothing was gunked up everything was great. Then I tried to start it, now it won't start. Gas is still getting to the carbs, but it won't fire. The starter will just keep going. Every Once and while it'll make a quick noise, as if it was going to start, but then quits. Some one anyone HELP!!!!!!!!!!!!!
Sassinm1
Sep 30, 2015 04:23 AM
Hack714
Sep 26, 2015 08:11 AM
black_thunder
Sep 22, 2015 07:59 PM
Hack714
Sep 20, 2015 05:54 PM
