Need technical help with my Raptor!
Old Jun 6, 2004 | 05:30 PM
sixsixT's Avatar
Default Need technical help with my Raptor!
Are you holding the tube up next to the carb with the other end facing up and above the bowl of the carb? If so your floats are sticking or there's crud on the needle valve and it's not sealing.
Old Jun 6, 2004 | 05:50 PM
Rook's Avatar
Yes, I did that and the tube is filling up with a lot of fuel, way above 1/8", so I took the bowls off and adjusted the metal tab downward a bit. That should do it right?
Old Jun 6, 2004 | 07:43 PM
sixsixT's Avatar
You want to bend the tab towards the needle to lower the level.
Old Jun 6, 2004 | 08:14 PM
Rook's Avatar
Which way is the needle. Are you talking about the needle in the bowl or the needle in the top of the carbs??
Old Jun 6, 2004 | 08:16 PM
  #15
sixsixT's Avatar
The needle valve that the float closes.
Old Jun 6, 2004 | 10:18 PM
  #16
Rook's Avatar
Allright, I bent the tabs downward, put everything back together. Then went back up to the mountains to try her out, and it's still doing the same thing. Is it possible I bent the tabs the wrong way, or is there something else that could be wrong?
Old Jun 6, 2004 | 10:37 PM
  #17
sixsixT's Avatar
Where was the float level?
Old Jun 6, 2004 | 11:18 PM
  #18
Rook's Avatar
I'm not quite following you. When I opened the bowls up, the float tabs were even, both of them were straight out, so i bent them downward. It started up just fine. Then I took the quad up to the mountains and it ran great until I hit an incline. Same as before.
Old Jun 6, 2004 | 11:25 PM
  #19
DEMENTED660R's Avatar
Raptor carbs are harder to get off than to tune...
pain in the @$$.
Old Jun 6, 2004 | 11:28 PM
  #20
sixsixT's Avatar
I guess you didn't read or follow the instructions in my post on how to adjust the float level. I don't know what else to tell ya.
