whats the best pipe for a YFZ450??
"Please correct me if I'm wrong."
You are very wrong. I will try my best to correct you since you asked, but I know there are alot more folks out there that know more exhaust physics than do I.
Take a stock engine with the lid off and a KandN filter. Dyno it with the stock exhast and you will get a baseline curve. Dyno it with a good freeflowing aftemarket exhaust like the Yosh, etc, and you will get a decent gain of power throughout the RPM range. Dyno it with an open header like the MBRP drag pipe and you will get crappy low end torque but maybe some top end gains. That is a fact. It works the same way on v-8s as it does with single cylinders. My truck is a great example. With a stock exhaust system it is OK. With a low restriction FLOMASTER catback system it gains noticeably on the top end but low end torque and towing ability is not quite as good. If I put a straight header on it it would MOVE at high RPMs but would lose ALOT of low end torque and power. It all has to do with backpressure and exhaust scavenging. It is just as big of deal with 4strokes as it is with 2smokes.
4stoke pipes with less back pressure are better to a certain point, then you begin to lose a lot of the low RPM power.
RR1
RR1
intresting...i heard the yousi were junk im not saying they are but thast what i heard and i am worried about the noise i think i can go for around 95 dbs but the alba has something near 100 thast crazy and i was wondering if any of you have seen the ATV power up kit it has 3 or 4 diffrent stages starting out with a K&N and outer wear and a few other things and the last stage has a new cam and the k&n and outwear and so on i was wondering i u would get any power gains from a cam? thanks
#17
Originally posted by: McFly
Ive heard from numerous sources that the GYTR pipe is handsdown the best.
I would personally go with Yoshi or Sparks next time.
#18
My friend just put the gytr on and it felt like a nice power gain, but I hope it's not going to fall off. I had not heard that they were doing this. Has any one else had this problem? The Yoshi system looked good but it's expensive and I did'nt know how loud they were. O yea, How much difference will a head pipe make? It's just that same damn thing in a lighter metal right?
Thanks for the Help.
#20
I have yoshi, and I am very happy, here is a place that you can get it and it is not to expensive in comparison to the rest Moto X Outlet $399 for complete Yoshimura system. Well I hope that helps!
