??? RAPTOR cam top gasket ???
Old Jun 10, 2004 | 04:13 PM
400exKiller990's Avatar
Default ??? RAPTOR cam top gasket ???
just purchased a hotcam and was wondering if the cam cover has a gasket or if its rtv? thanks
Old Jun 10, 2004 | 04:23 PM
RedBullGotWings's Avatar
im not sure what an rtv is but there should be an o ring inside the cover
y? is it leaking oil? mine did the same but i rid it and it stopped
Old Jun 10, 2004 | 04:25 PM
rtv is a silicone sealant it looks like that is what it has in it. im pretty sure there is an o ring inside. no oil leak just replacing cam
Old Jun 10, 2004 | 04:36 PM
warwgn's Avatar
there is no o-ring, at the factory they use a compound called yamabond. I use the red rtv(high temp) it works like a champ, just let it sit for about an hour before you put the cover back on or it will smear. try not to go more than about a 1/16 inch bead.
Old Jun 10, 2004 | 04:42 PM
sparkskiller's Avatar
the head and cam cover are a matched set no not mix them.
the cam cover is a precision fit also, so no gasket is required.
use only yambond #4 or three bond1211 for this. using other gaskets sealents and letting then cure befroe use will create a larger gap than was setup from the factory and will create a loss in oil pressure, sloppy cam bearings where the cam will wobble alittle in the head.
Old Jun 10, 2004 | 04:50 PM
warwgn's Avatar
if you stay thin on the high temp red it will seal very well, it wont completly cure for about 24 hours, the one hour is only so it will get tacky, not cure hard. and when you bolt it down most of it will squeeze out and only seal the imperfections, thats why you want to use less than 1/16 inch
Old Jun 11, 2004 | 02:13 AM
ill GITTER DONE with rtv
bmxatv10
Oct 14, 2022 06:23 PM
tysonbully
Sep 28, 2015 02:30 AM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 12, 2015 09:39 AM
