Raptor Tech Guys...Piston Options...
Old 06-14-2004, 07:17 PM
Yamaha660R's Avatar
Default Raptor Tech Guys...Piston Options...
There is a place here that sells race gas. It's relatively close, so that won't be too much of a hassle or problem. But I think the gain will be worth it. The 11:1 performs well, but 2-3 lenghts would put me infront of most of the competition. I'm planning on pushing the 686 as far as I can to see what I can get out of it. I haven't seen a higher comp. piston yet for the 686, and I can sell the 11:1 as it is, since it probaly only has 5hrs on it, if that.
I'm going to try the higher comp. piston and see where it goes from here. But I defintely understand your view. Race gas can be a pain to get in some places. It's definetly not at every gas station you come to.
Old 06-14-2004, 08:43 PM
RoostItUp's Avatar
I have a 12:1 piston and I believe it drops reliability dramatically over the 11:1. 13.5:1 would be ALOT of compression and I don't think it will be very reliable, to much compression is what screwed my engine over both times now. The HP gained isn't worth the reliability lost and the extra money spent, you won't notice alot of power difference from the 11:1 much either.
Old 06-14-2004, 09:19 PM
wshrdskin's Avatar
Since my name was brought up.
Any increase in compression will lessen the reliability imo. You have replaced the rod with Carrillo and had the crank balanced. In theory you should not have any problems with that area. I'd go 13.:5:1 imo.
The increase was noticable but I went with a top end cam at the same time. 1BadRaptor went from an 11:1 to a 12:1 at one time and picked up a few bike lengths just from that.
You should notice increased bottom end for sure.
Old 06-14-2004, 10:06 PM
Yamaha660R's Avatar
I've went all out on the 686...with the exception of the low compression piston. I have the FCR's, and I did all the crank and rod work. So I'm not scared to go up to the 13.5:1. The piston will be here and installed within 10-14 days, so I'll let you guys know how it works out. I think the increase will be noticable because I'm going from a low comp 93 octane pump gas set up, to a 13.5:1(14:1) 110 straight race gas set up. I'm defintely looking forward to how it runs.
  #15
Old 06-15-2004, 01:03 AM
RaptorOwner's Avatar
I can bet you that when you set this up and get it tuned right with jetting and all, you will have a smile from ear to ear!!![img]i/expressions/face-icon-small-happy.gif[/img]
I know I do..... hehehehehe.
Alky, I have never tried it but I sure do like how it runs alot cooler though.
  #16
Old 06-15-2004, 01:26 AM
Yamaha660R's Avatar
I have thought about alky, but some say if you leave it sit that it will eat away at your seals. So I think 110-116 race gas will suit me just fine. [img]i/expressions/face-icon-small-happy.gif[/img]
  #17
Old 06-15-2004, 01:29 AM
Oh, yeah, that is why I didnt want to run that stuff either. My buddy all ways has to drain his whole bike then run race gas thru it each time he puts it up.
  #18
Old 06-15-2004, 01:34 AM
Yamaha660R's Avatar
I've been told the samething, and that is way too much of a hassle for me. I'll just stick to the high octane race gas, and not have the hassle of the alky.
bmxatv10
10-14-2022 06:23 PM
r1pilot83
09-27-2015 07:38 PM
black_thunder
09-22-2015 07:59 PM
Alex Rodak
09-13-2015 12:30 AM
Alex Rodak
09-12-2015 09:39 AM
Quick Reply: Raptor Tech Guys...Piston Options...
