possible without stator
Old Jun 20, 2004 | 12:18 AM
soon2bBlaster's Avatar
Default possible without stator
is it possible to ride normal if the stator is messed up from a broken woodrov key? i think all the stator does is generate electric for the light and if i take out the light for the race plastics i dont need to spend money to fix it. am i right or do you need the stator to ride.
Old Jun 20, 2004 | 12:21 AM
warrior68man's Avatar
Your stator powers you bike...everything electrical on your bike.....if It starts...then it should run fine...if it doesn't start..you need a new stator.
Old Jun 20, 2004 | 12:37 AM
its not starting but i hear a grinding sound so it might just be the degree key broke off. also how much am i lookin at for a new stator
Old Jun 20, 2004 | 12:50 AM
around 200 bucks for an aftermarket one...call up eastcoastatv (www.eastcoastatv.com) they have used ones and rebuilt ones for pretty cheap...give em a call.
Old Jun 20, 2004 | 12:53 AM
how can a stator get ruined so easily what could have happened. if i did ruin it. maby i just need a new woodrov key to solve my problem. i hope thats all it is
Old Jun 20, 2004 | 01:00 AM
That's probably it...the stator won't make a grinding noise if its bad...check for spark before you do anything.
Old Jun 20, 2004 | 01:04 AM
i definately think its something to do with the key because the flywheel nut was almost off when i took off the cover. and if it is broke the piece that is floating around in there is what is causing the grinding. nice icon i see u just changed it.
Old Jun 20, 2004 | 01:21 AM
Thanks...that's the Warrior....just painted frame and a arms and motor and axle and etc....waiting for my stator..and black seat cover.
Old Jun 20, 2004 | 01:27 AM
i just looked at HDP's site and it looks like they know what they are doing. when you buy their 240 kit you need a bigger carb rite?
Old Jun 20, 2004 | 02:30 AM
daputz's Avatar
Last time I ran across a broken key the fly wheel nut came off by hand as did the fly wheel. While you are in there look things over and make sure the stator doesn't show any obvious signs of damage.
Yes you can run a stock carb with a big bore, but it will limit your top end power. If a new larger carb is outta the budget, the 34mm pj's are plentiful and affordable, check ebay (search 250r carb, 34mm keihin, 34mm pj).
ultangler
Nov 30, 2024 01:35 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
kbazzy
Sep 26, 2015 11:26 AM
johnny1982
Sep 13, 2015 07:41 PM
zPuls3
1) Engine problems..
Sep 12, 2015 08:54 AM
