Hard or Easy
Old Jun 21, 2004 | 04:15 AM
FaSsO's Avatar
Default Hard or Easy
is it hard to put in new main jets for a 04 raptor?? and doe s this sound right to you?? 150 main jet left carb and 155 main jet right carb for a big gun slip on and k&n. i looked on big gun's website and thats what it said to jet it
Old Jun 21, 2004 | 04:18 AM
caliraptor's Avatar
pretty easy....just remove the lights, plastics and fuel tank. pull the carbs from the boots, flip them over and unscrew the bowl and change the jets
Old Jun 21, 2004 | 10:32 AM
Yamaha4eva's Avatar
the lights?
Old Jun 21, 2004 | 10:49 AM
Stoppie's Avatar
Yes, you have to at least take the top bolt out of the lights.
Old Jun 21, 2004 | 08:59 PM
maddog56's Avatar
Mikuni or dynojet/K&N jets? Are you running an airbox lid or not? If you are, are you putting any holes in it or leaving it stock? What elevation are you at?
Old Jun 21, 2004 | 10:03 PM
FaSsO's Avatar
iam runnin gytr main jets i got them in and everthing fine it reali rips now thanks for the help i am runnin stock air box i sit better to drill holes in it??
Old Jun 21, 2004 | 10:25 PM
maddog56's Avatar
If you plan on riding in wet or muddy conditions, leave the cover on. The more you open the intake up, the more power you will get. Unfortunately, drilling holes makes jetting a little harder because of the varied size of the holes. If you usually stay pretty dry I would remove the lid and run an outerwear.
Ridgerunner665
Sep 15, 2015 01:20 AM
bvolks
Sep 13, 2015 12:57 PM
Rick Van Matre
Sep 11, 2015 11:52 PM
essonlaker
Sep 10, 2015 01:12 PM
Elkaholic
Sep 6, 2015 02:44 PM
