how many cc
Old Jun 23, 2004 | 07:36 PM
  #21
xraptor660rRider's Avatar
Default how many cc
i would like you to do the math but i dont know wat u mean
Old Jun 23, 2004 | 11:01 PM
  #22
Default how many cc
bump
Old Jun 23, 2004 | 11:10 PM
  #23
radfastdude7777777's Avatar
Default how many cc
Here is my question- Why can't it be simple, such as .030 over, or .30 over would make a 350 into a 380? I know nothing about boring, so please, bare with me!
Old Jun 24, 2004 | 12:12 AM
  #24
maddog56's Avatar
Default how many cc
the .030 is a measurement of the material taken out of the cylinder wall. It is therefore the size in which the piston must increase in order to properly seal. It means that .030 thickness of material has been removed from the cylinder.
Old Jun 24, 2004 | 01:25 AM
  #25
roosthrower's Avatar
Default how many cc
and .010 over equals .25mm larger piston. so if you are .030 over the bore of the banshee would be 64.75mm while the stock bore is 64mm.
here is the formula I like to use:
1/2bore x 1/2bore x stroke x pi x number of cylinders
I'll plug in the numbers this time:
3.2375 x 3.2375 x 6.4 x 3.14 x 2 = 355.44544875
I'm 15.
