Kibble White valve springs?
Old Jun 23, 2004 | 09:43 PM
bad350twin's Avatar
Default Kibble White valve springs?
I recently got back from a horrible running weekend at are local jamboree..... my machine was put together the morning of and had a whole list of problems with her upon arrival! To make the story short at idle my quad sounded like purging a set of alky carbs with gas..... when i got home i recently pulled the head and low and behold i have a brong exhaust spring!!! I was wondering.... should i just replace that valve and spring, or replace all valves and springs to be safe! if doing that this could be a expensive fix!
Old Jun 23, 2004 | 10:43 PM
sixsixT's Avatar
Were both springs broken? Did you pull the head?
Old Jun 23, 2004 | 11:42 PM
pinheadedjoker's Avatar
sounds like you need to get a new valve.. and then get some heavy duty springs.. if u just had stock springs and u had cam work then.. yeah get it fixed.. bound to be more problems
Old Jun 24, 2004 | 01:17 AM
bad350twin's Avatar
Actually the only spring that broke was the middle one in the back! the springs are heavy duty and have 1mm over titanium valves and retainers! i was just wondering if anyone has had a build with a few seasons on it that had any trouble with the springs!
Old Jun 24, 2004 | 07:09 AM
Ward660R's Avatar
14mins broke one.
I am pulling my cover to check mine out. I am about half way done...will post the results later today I think.
If I had broke one, I would pull the rest of them and check the tension on them.
Did it hurt anything else? Bend a valve?
Old Jun 24, 2004 | 12:36 PM
bad350twin's Avatar
i havent had time to pull the actual head off yet.... i have just pulled the very top (cam cover or whatever its called) so i will pull the head a.s.a.p and look! i got real lucky with the piece that broke of just setting in the back of the head! at least this gives me a reason to take off the head and take a look at my JE piston after hearing all these horror stories about them!
Divergent12
Dec 30, 2017 08:33 PM
brinkkl2000
Oct 16, 2015 11:08 AM
Polarisman1123
Aug 3, 2015 02:08 PM
Aitch
Jul 21, 2015 09:40 PM
Mphillips
Jul 2, 2015 07:20 PM
