Raptor idling fine give it the gas and sputters
Old Jun 27, 2004 | 09:07 PM
Bass's Avatar
Default Raptor idling fine give it the gas and sputters
My raptor will idle fine the when I give it the gas it will sputter as though the e. brake rev limiter is kicking in, but I took the brake off, an put a new clutch perch on. I may have done something wrong, all I did to the connectors on the clutch was just cut the wires. It has ran for over a year like this, and it wont do it all the time, today I couldnt get it to run at all, then bang out of the blue it fixed it's self. Can someone please give me anything to try?
Thank you
Old Jun 28, 2004 | 07:11 PM
Bass's Avatar
anyone?
Old Jun 28, 2004 | 07:21 PM
tintman's Avatar
have you checked to make sure you have no corrosion on any connectors i would suggest soldering and shrink raping for any connections.not to say this will fix it but check to be sure.
Old Jun 28, 2004 | 07:45 PM
sixsixT's Avatar
Yeah it sounds like a wire is shorting to ground.
Old Jun 30, 2004 | 10:38 PM
400exKiller990's Avatar
have you checked the rev limitors?
Old Jun 30, 2004 | 11:50 PM
UBETRUN's Avatar
When you removed the p-brake and clutch perch, did you connect the bullet connectors beside the radiator to each other? If not, it won't start in gear and the rev limiter will act goofy. If it's an intermittent problem, it might be the reverse rev limiter connection under the front sprocket.
Old Jul 1, 2004 | 12:10 AM
pinheadedjoker's Avatar
go to www.raptortranny.com go to the bottom and check out the reverse rev limiter.. there is a quick fix for it from what ur saying it sounds like the same problem i had this fixed it right up in 10 min flat..and they say its been known to happen on 02 raptors so yeah check that out fixed mine should fix urs
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jul 5, 2015 09:04 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
yambam13
Jul 4, 2015 01:49 PM
