Raptor Jetting Please Help
Old Jun 29, 2004 | 08:15 PM
wrench12123's Avatar
Default Raptor Jetting Please Help
can you raptor guys help me out, Rider1169 and I are going to the track this weekend and he just orderd an hmf slip on for his raptor and he wanted me to get specific derections on how to jet his carbs. PLEASE help, if anyone replies can you make it VERY specific, like every step. we dont want to mess this up. Thanks
Old Jun 29, 2004 | 08:23 PM
pinheadedjoker's Avatar
get the jets.. Then take off the front plastics.. u can search around and find the bolts that are nessicary to take off. then turn off the gas on the switch and dissconnect the tube that goes from the tank to the carbs. then remove the 3 tank bolts .. then.. take off gas tank and get it out of the way .. now get a allen wrench and loosen the 4 allen bolts that hold the boots on and then slide the other tubes that are connected to teh carbs out of the way.. flip the carb over and very carefully undo the 4 (well 8) but 4 screws on teh botom of the carbs that hold the bowls on make sure u dont strip them.. then in the middle of the carb is where the main jet is take a flat head and unscrew it and then replace the new jet.. then do it to the other side.. then put it back together the way u took it apart dont tighten the bowl screws way to tight because they are hard to get back out [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jun 29, 2004 | 08:32 PM
thank you pinheadedjoker[img]i/expressions/face-icon-small-cool.gif[/img]
Old Jun 30, 2004 | 11:55 AM
no problem.
Old Jun 30, 2004 | 11:57 AM
Rider1169's Avatar
you dont have to adjust any screws or clips or anything? or neeedles, just put in the jets and ur good?-thanks rider1169
Old Jun 30, 2004 | 12:01 PM
well you need to change ur needle position to what works best for you. its easiest to start at the 3rd clip position and work from there. to get to the needles all you need to do is take the gas tank off then undo the black tops of the carbs. pull out the diaphram being carefull then pull out the needle and adjust it. the fuel air screws may need to be adjusted but for a simple slip on i wouldnt change it to much. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jun 30, 2004 | 12:07 PM
Rider1169's Avatar
thanks
Old Jun 30, 2004 | 01:17 PM
Fast5Ty's Avatar
If you are putting on the slipon, are you going to replace the air filter and air box lid as well? I put the GYT-R slip on on my Rappy as well as replaced the original slip in filter with the K&N slip in filter and the K&N power lid. I think if i had it to do over i would have gotten the Pro Filter witht he aluminum adaptor. Anyways, when i boutht the filters and the slip on i ordered the GYT-R jet kit. It had a new pilot jet, new needles, and plenty of new jets. I have my carbs set as follows:
25 pilot jets
GYT-R Needles with clip in middle notch
160 main on the left carb and 165 main on the right carb
air screw on left carn three turns out, two turns out on the right carb
that is what the instructions recommended and i havent had any trouble since i got the fuel level set finally.
The fuel level on mine is set right at the mating surface, to measure it take a piece of 1/8inch clear tubing, cut it off about a foot long and slip in on the bowl drain nipple. Hold the tube up beside the carb and open the drain screw, the fuel will flow into the tube and show you the fuel level.
Good luck on this little adventure, Plan on spending a coule of hours or an afternoon to get it all right and try not to pull out too much hair over it.
Later Tyson
Old Feb 18, 2005 | 10:05 PM
bronzeback's Avatar
i have a 04 raptor i just put a hmf slipon and a k&n pro flow kit, i cleaned out my airbox completly except where my adaptor plate sits, i jetted my carb with a 155 left and a 160 right, i live in st. louis and the weather today was about 50 my bike ran great no sputtering spitting and it pulled great thru all gears no problem
bmxatv10
Oct 14, 2022 06:23 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
