U joint removal
Old Jul 1, 2004 | 08:47 PM
ztec's Avatar
Default U joint removal
Are there any u joint specific tools need to remove the u joint on a 99 big bear. I assume you need a snap ring remover or somthing like that but after you pull the snap rings or c-clips is it free? What else is involved.
Old Jul 1, 2004 | 11:30 PM
LotusPosition's Avatar
Soak them good with penetrant a day or so before hand. The cups on the joints are press fit, so once the clips are out, you will need to press or tap them apart. A strong c clamp, or hammer and socket, slightly smaller than the cup od are the usual tools. Take a look at the new parts to see how they are assembled. Be patient and don't use extreme violence.
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Canamaniac!
Sep 15, 2015 06:19 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
89Lt250r
Sep 7, 2015 07:53 PM
