warrior problems with staling
Old Jul 4, 2004 | 10:52 PM
DS650BajaRunner's Avatar
Default warrior problems with staling
Sure but i cant today il have to do it tomorrow its very late here but i will let you know as soon as possible first thing tomorrow.
Old Jul 4, 2004 | 10:54 PM
bvwarrior's Avatar
no problem i'm going to bed it is 10:00pm here . my bike runs i'm only wondering if it is normal not to line up perfectly
Old Jul 5, 2004 | 03:33 PM
I removed everything but i could not remove the 1 allen screw that is located on the head it is broken and i tried various times to remove it and now is broken so i will have to buy a new one. Now that is broken i cant remove it as easy. Sorry man i tried if in the future i remove it and time it to see if its correctly timed i will let you knoe i promise [img]i/expressions/face-icon-small-wink.gif[/img]. You can keep riding, as long as you dont hear strange noises and the bike performs perfectly you should not be worried.
Old Jul 5, 2004 | 03:46 PM
bvwarrior's Avatar
thanks anyway ds650bajarunner
Old Jul 5, 2004 | 03:49 PM
  #15
No prob. Thanks for helping me out also.
Old Jul 5, 2004 | 05:51 PM
  #16
I have a question My bike has 2 sensors one is where the parking brake is the other in the clutch perch but i do not know wich one to remove? bvwarrior you unpluged the sensor to your clutch all i have to do is remove the sensor and throw it away or i can remove both of them? is it also necessary to remove the parking brake assembly on the handle bar or keep it for looks?
Old Jul 5, 2004 | 07:04 PM
  #17
anyone????
Old Jul 5, 2004 | 07:20 PM
  #18
bump
Old Jul 5, 2004 | 08:01 PM
  #19
Now i have a bigger problem i removed to parking brake sensor the whole thing but then suddenly without touching nothing it was trying to turn on by itself! i didnt even hit the start button it just tried to turn on i had to remove one cable from the battery to make it stop please some one help me on this!!
Old Jul 5, 2004 | 11:23 PM
  #20
bvwarrior's Avatar
ok your bike is newer then mine. yours has a brake light, right ? mine doesn't. i would leave the sensor for the parking brake in, but remove the one on the clutch perch. but just take it out of its little hole and do not disconect the wires. because if you disconect the wires, each time you stall it, or if it shuts off some, how you will have to put the bike in neutral or you will have to turn on and off the key to start it again.
